TwinTurbo.NET: Nissan 300ZX forum - Re: The pump reads PSI and BAR. I'm not sure what a schrader
DualZ
on December 27, 2007 at 12:04 AM
posted by MAD_96TT
on December 26, 2007 at 11:54 PM
the schrader valve is like the little valve on tires that lets air in/out when it is pushed.
Am I doing this wrong?? (Boost Leak Tester)
MAD_96TT
23:34:43 12/26/07
Re:your bike pump does not move enough volumne.
tognot
23:48:15 12/26/07
what happens if you exceed 5 psi? (n/m)
nemo1080
03:05:54 12/27/07
You can blow out your seals (n/m)
ChrisZTT (Sacto, CA)
07:33:58 12/27/07
Didn't they include instructions?
SactoTodd
23:48:42 12/26/07
nope...no instructions. (n/m)
MAD_96TT
23:51:46 12/26/07
instructions on their site (n/m)
ali300zx
23:54:42 12/26/07
I have a compressor, but I didn't want to use it b/c I am
MAD_96TT
00:00:50 12/27/07
Re: also, if your pump gauge reads psi, the schrader
tognot
23:50:27 12/26/07
MAD_96TT
23:54:00 12/26/07
Re: The pump reads PSI and BAR. I'm not sure what a schrader -
DualZ
00:04:06 12/27/07
DualZ
00:04:51 12/27/07
Someone please correct me if I'm wrong... BUT..
PiotrC70
00:04:45 12/27/07
It takes a good minute or two to fill the intake tract
ShakaShaun(Denver)
00:11:23 12/27/07
Thanks for the help....I hooked up the compressor and it is
MAD_96TT
00:27:15 12/27/07
FYI when looking for leaks near the DS turbo don't forget to
240Z FeO2
01:26:11 12/27/07
You set the compressor @ 150psi? You're crazy
Crim
05:26:18 12/27/07
He must have had a BIG leak. (n/m)
07:36:25 12/27/07
lol
aliaZ
00:38:34 12/27/07
You need a air compressor, that has a air regulator on it (n/m)
Eishozzzz
03:23:15 12/27/07
Wow. (n/m)
Kenny
08:35:39 12/27/07
I use a compressor with no regulator.
Woody75 (Denver)
08:53:45 12/27/07
same here..
zfreak(Denver)
03:14:55 12/28/07
